NI TestStand
Custom test types configurable
I'm trying to make a custom step type that works like the limit is working in ex. Numeric limit test. What I want is a new pane called "Test" with 1 field that can be modified by inserting a variable or just a value ex. 2 like you can in the Limit Tap, I have made a step where you can edit this by clicking a button that opens a LabVIEW vi and from there you can change it, what I'm trying is to make it so that you can change it from Test Stand  without having to open LabVIEW, but also so that you can insert a variable...
Attached is a simple picture showing what I want...
/Marck H Hansen
Marck Holm Hansen
Tech Lead at GPower | LabVIEW Architect | TestStand Architect | Bachelor of Electrical Engineering | Admin, LabVIEW.dk
(3,383 Views)
Accepted by Marck_GPower
Hello Marck,
At the moment there is no offical support for this feature.
I recommend to to visit this Idea http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Ability-to-create-user-built-in-StepTypes/idi-p/1...
and fire a kudo to it....
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,361 Views)
