NI TestStand
Customize NI Operator Interface!?
Hi
Im using Labview 8.5 Base and TestStand 4.0 Development System!
Now I want to deploy my teststand sequences to an other PC! I Want to use the Operator Interface from NI "C:\Program Files\National Instruments\TestStand 4.0\UserInterfaces\NI\Full-Featured\LabVIEW"! In this Operator Interface you can press "CTRL+F5" to execute the sequence! How is it possible to change the Keyboard-Command for execution to "F5"? I searched the "Load Top-Level VI.vi" for something like that but I didn't find anything!
I hope someone can help me!
Message 1 of 9
(5,663 Views)
Try Tools>>Options>>Menu Shortcuts
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 2 of 9
(5,646 Views)
Sorry that was bad info. I'll keep digging. Usually you can right click the control and select advanced>>key navigation. But on the operator interface the key navigation selection isn't available.
Message 3 of 9
(5,640 Views)
The LabView operator interface uses Activex controls not native LabView controls.
Message 4 of 9
(5,639 Views)
Is it possible to modify them? And How?
Message 5 of 9
(5,593 Views)
Can nobody help me how to change the Keyboard Commands?
Message 6 of 9
(5,501 Views)
There are defined in an ini file in the \componenets\NI\language folder. I cannot remember the actual name of the file but you will see  the obvious one when you look that folder.
You dont modify this file but put the Section key and the key with its new values in the CustomStrings.ini file in the User\language folder.
You dont need to add everything thats in the default file only the items that you want to change.
When TestStand launches it will use the values in the CustomStrings.ini instead of the default ini file.
Regards
Ray Farmer
Regards
Ray Farmer
Message 7 of 9
(5,490 Views)
Thanks for your answer!
I couldn't find a file with Keyboard Shortcouts! I searched all the *.ini files in the language folder and couldn't find it!?
Message 8 of 9
(5,459 Views)
Hey Cardinal,
I just wanted to let you know that this was reported to R&D (# 51232) for further investigation.  It should be easier to change the shortcut key in an Operator Interface than it currently is.  Sorry for the inconvenience.  Have a great day!
Best Regards,
Software Engineer
Jett R
Message 9 of 9
(5,271 Views)
