NI TestStand
EditTimeMenuItem.ItemTextExpression using String Input
i have created a Sequence File to configure the Sequence Editor (4.0) Tool Menu dynamically. Now i have a question about the ActiveX Function EditTimeMenuItem.ItemTextExpression, which need a String as Input. Take an example: to set the name of a new Menu to "New Menu", i must type "\"New Menu\""  instead of "New Menu". Otherwise i get the Menu Name "Unexpected token: Menu".
I think it maybe a small mistake in the value transfer, isn't it?
ItemTextExpression Property
Syntax
Data Type
String
Purpose
Specifies the expression TestStand uses to determine the menu item text at run time.
Regards
MY
(3,697 Views)
The string must be an expression.  The string will be evaluated, so if you are providing a constant string value, the quotes marking it as a constant need to be escaped when defining the string (depending on what environment you are setting the property).
Allen P.
(3,693 Views)
Hi Allen, thank you for your quick answer.
But i still don't understand, why the Input format of this String is different than that in Function EditTimeMenuItem.EnabledExpression or in Function EditTimeMenuItem.HiddenExpression? Both are Expression.
Regards
MY
(3,689 Views)
The enabled expressions must evaluate to a Boolean.  The ItemTextExpression must evaluate to a String.
(3,678 Views)
