NI TestStand
Customize on the fly
I want to customize on the fly report such that the report should not contain the information about the sequence call name. I am able to do this for normal reports(with out on the fly option) by tweaking the process models such that the unwanted information is filtered out from the resultlist container.
But for this on the fly report I am not able to remove out the unwanted sequence names, start of sequence header, end of sequence headers as all of this is getting added to the report just by using one step "Process Step Result" present in "ProcessOTFStepResult" sequence.
Any help in filtering out the unnecessary data is appreciated.
Ramjee V
(3,217 Views)
 If you find editing the "ProcessOTFStepResult" sequence so complex,  you can change the style sheet which will parse the necessary fields in the XML report and show the report to the user.
AshwiN,
(3,157 Views)
Thanks for you time.
Right now we are working on txt and html report. To customise the report of this kind what changes should i do?
Ramjee V
(3,154 Views)
