NI TestStand
password protected files
I use the property loader in TestStand to load values from various configuration and limit files.
Our client has requested that the configuration and limit files be password protected so that they cannot be altered in the factory.
We use AxCrypt to encrypt and password protect our files.  It's an open source encryption program.  Does anyone know if there is there a way of passing a password to the file using the property loader?
Sean
(2,986 Views)
What is the teststand version that you are using?
You can set Developer profile Privileges>Configure>Edit Process Model to false.
and Configure>>Sequence Editor Options>>All Editing of Read-Only Files
(2,947 Views)
