NI TestStand
DLL calling a subsidiary static library
I've built a DLL using labwindows that calls a subsidiary static library. I've added a step in Test Stand that calls this DLL.  On my development station all is good.  The subsidiary library is called.  But, on a deployed station I keep getting a "Cannot load DLL".
According to the reference manual, I can preload the subsidiary librarys by using the CVI adapter.  I get the same error on my deployed station...
(4,198 Views)
Accepted by JamesSid
You get an error "Could not load a DLL" when one of the dependencies is missing.
Please check it this way :
Download free dependency walker --- http://www.dependencywalker.com/
Select the DLL ( deployed machine).
It will show which dependency component is missing in the deployed machine.
For CVI..
Since you are using a static libarary - did you include it in the build when you build the project?
It should be embed within your DLL. ( using add files to DLL option in the CVI target settings).
Hope this helps.
(4,183 Views)
I tried the dependency walker.  A very nice tool.
After running dependency walker on my DLL, it threw an error that I was missing a DLL.  Turns out I had configured the target settings on one my static libraries as a DLL rather than a static library.  Changed the settings and rebuilt it.
Once I get access to that deployed bench again I'll check it out, but I'm pretty sure this fixed the issue.
Thanks for the information...
(4,175 Views)
Still get the same error.
I've added the static libraries in the target settings of the CVI project, including adding the libraries in the Test Stand adapter.
(4,169 Views)
After posting my last message, I realized my problem.
I recently upgraded Labwindows to 2012, but my deployed station only has the 2010 rte.  so, I rebuilt using version 2010 and all is good now...
Thanks for the help and sorry for the confusion.....
(4,167 Views)
