DMM IVI read measurement update
What is the sequence Read U2741A doing?
Regards
Ray Farmer
Message 11 of 16
(1,757 Views)
Hi Ray,
 U2741A.seq doing nothing its skipped. see attached file for cct.
Regards Mehran
Mehran Fard
Message 12 of 16
(1,755 Views)
Doh!
Regards
Ray Farmer
Message 13 of 16
(1,742 Views)
Hey Mehran,
Im a little confused as to why you would want to read the values of the DMM proir to the IVI call? Is there a specific reason for this or were you interested to know why the voltage change so much post IVI call?
Regards
Andrew George @ NI UK
Message 14 of 16
(1,721 Views)
Hi Andy,
We record an external DMM reading to validate our test software.
Basically we only use external DMM during validation/verification to prove our measurements to the customer and producing validation document.
Regards
Mehran
Mehran Fard
Message 15 of 16
(1,715 Views)
Accepted by Fardm
Hey Mehran,
For the perpose of validation you should use the voltage value of the DMM after the call of the IVI driver, the reason for this is that the voltages measured are scaled and therefore the driver is necessary to produce a final and accurate measurement.
Regards
Message 16 of 16
(1,694 Views)
