NI TestStand
DaqMX parallel executions error -50103
Hi all,
I am working on a system with 16 test sockets. I am using a PXI system with PXIe-4357 RTD cards, each station has 2 RTD's. If I run 1 or 2 stations it works well, if I try to run 3-4 stations simultaneously, I get error -50103. I have set my VI's to be non-reentrant and I have used the Task Done VI and I unreserve and clear the task. This VI is called by another VI which is in a TS loop. The loop runs pretty slowly, and I have implemented a 0.5s delay.
Does anyone know how to solve this issue? Please see my VI attached.
Thanks!!
(4,852 Views)
If you are calling multiple instances of the attached VI from TestStand and more than one instance is creating a task on the same card you will receive that error. I would recommend ensuring that all channels per card are part of the same task to avoid that error.
RF R&D
(4,779 Views)
You need to be carefull when using multiple test sockets and calling instruments.
As suggested below, it might be a good idea if you make a task where you call all the readings at the same time. and you can run that as a Thread on the background always and write the value to a FileGlobal or StationGlobals.
CLAD, CTD
(4,752 Views)
Thanks for the replies!
I ended up making a single task in a background thread which reads all of my sensors into arrays, then I pick off the data required per socket.
I was under the impression that setting the VI's as non-reentrant would allow my original idea to work as only one thread had access to the VI at any given moment. Guess I was wrong!
Thanks again!
(4,750 Views)
