NI TestStand
TestStand Callbacks....CancelStepCallback
I have two sequence callbacks, PostStep and StepFailure. I am wanting to use Step.CancelStepCallback inside of the PostStep callback, since it is called before StepFailure, so StepFailure callback is not executed, on certain occasions. Is there a way to do this? I have tried "CancelStepCallback" with no luck.
(4,830 Views)
Hi TreyB
What do you mean with:
" I am wanting to use Step.CancelStepCallback inside of the PostStep callback, since it is called before StepFailure, so StepFailure callback is not executed, on certain occasions."
My curiosity is the last statement:
" on certain occasions."
Warm Regards,
Sigi
AE
"everything is achieveable through technology'
(4,748 Views)
I think I have created a work around but what I was trying to accomplish was retesting a numeric limit step, if it failed, without displaying a failed status to the script and report. So, on the first test check, I would go into the PostStep....if there was a failure I wanted to cancel callbacks and go to specific step to retest. Instead the script would execute my PostStep callback and also the PostStepFailure callback and leave a Failed status.
Reason, I have operater entered values through a popup. This could lead to operator error. I have a limit test step that checks these values. Without adding addition steps, I wanted to confirm the value, if a failure, repeat the prompt for value re-entry...do not show a failure on the limit test step. After a second value entry, if it still is a limit test failure then proceed.
I have a work around instead of using callbacks right now. I am using the Looping tab feature currently with success. I originally was wondering if I called the "CancelStepCallback", inside of PostStep callback, why would the PostStepFailure callback still execute.
(4,741 Views)
