NI TestStand
Programatically closing an execution fails unless I select Auto close
Hello there!
Im trying to execute a sequence using TestStand API and then close all references, but the End Execution event does not seem to be thrown.
I had the same issue as the thread called " Programatically closing an execution" from 2009.
My code is the following
_axAppMgr.EndExecution += new NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_EndExecutionEventHandler(_axAppMgr_EndExecution);
_axAppMgr.ExecutionClosed += new NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_ExecutionClosedEventHandler(_axAppMgr_ExecutionClosed);
void _axAppMgr_QueryCloseExecution(object sender, _ApplicationMgrEvents_QueryCloseExecutionEvent e)
e.opt = QueryCloseExecutionOptions.QueryCloseExecution_AutoCloseWhenDone;
void _axAppMgr_EndExecution(object sender, _ApplicationMgrEvents_EndExecutionEvent e)
ExecutionRunStates runState;
ExecutionTerminationStates termState;
e.exec.GetStates(out runState, out termState);
if (termState != ExecutionTerminationStates.ExecTermState_Normal)
Trace.WriteLine(DateTime.Now + " -----EXECUTION " + e.exec.DisplayName + "Aborted ---------");
else
Trace.WriteLine(DateTime.Now + " -----EXECUTION " + e.exec.DisplayName + " Terminated ---------");
ExecutionEnd = true;
public bool Run(string UUTName, string sequencePath )
bool output = false;
int TimeOut = -1;
string name = "";
ExecutionTerminationStates TerminationState;
try
name = DateTime.Now.ToString("yyyy-MM-dd") + " Test " + UUTName;
if (!_axAppMgr.IsStarted)
_axAppMgr.Start();
seqFile = _axAppMgr.GetEngine().GetSequenceFileEx(sequencePath);
Main = seqFile.GetSequenceByName("MainSequence");
Main.OptimizeNonReentrantCalls = true;
Main.Type = SequenceTypes.SeqType_ExeEntryPoint;
execution = _axAppMgr.GetEngine().NewExecution(seqFile, "MainSequence",null, false, ExecutionTypeMask.ExecTypeMask_CloseWindowWhenDone);
execution.TracingDisabled = true;
execution.RTEOptionForThisExecution = RTEOptions.RTEOption_Ignore;
execution.ClearTemporaryBreakpoints();
execution.DisableResults = true;
bool isExecuting = seqFile.IsExecuting;
bool wait = execution.WaitForEndEx(TimeOut, true, null, null);
execution.GetStates(out runState,out TerminationState );
execution.Terminate();
_axAppMgr.SetAutoCloseExecution(execution, true);
_axAppMgr.CloseExecution(execution);
execution.GetStates(out runState, out TerminationState);
while (!ExecutionEnd)
System.Threading.Thread.Sleep(1000);
Terminate();
catch (COMException ex)
Trace.WriteLine(ex.StackTrace + " " + ex.Message);
finally
TSHelper.DoSynchronousGCForCOMObjectDestruction();
Quit();
return output;
The problem is, when I deactivate the
command the execution fails to close.
If I set the option to
  e.opt = QueryCloseExecutionOptions.QueryCloseExecution_ShowDialog;
and manually select auto close , then the Execution Close event is thrown.
Could anyone help me finding out what's wrong with my code?
Thank you in advance for your time
(4,291 Views)
Anyone ??
(4,207 Views)
