NI TestStand
Data Logging from Veristand at a different time rate other than (ms) ?
During data logging from Veristand, the data is automatically logged per 1 ms is there any way to change that, It doesn't follow the Rt-sequence timing? and when closing the data log file it get's stuck at that step in test stand , What steps should i take to solve the issue ?
(2,702 Views)
Hi Amah,
What steps are you doing to log data? I'm having trouble following what steps you're using. Are you using NI VeriStand Steps for TestStand or are you using Stimulus Profile/Real-Time Sequence Editor? VeriStand Steps for TestStand has it's own feedback forum that may get you quicker access to support.
Best,
Chris D. | Applications Engineer | National Instruments
(2,658 Views)
