NI TestStand
Database error in TS4.1
I upgraded from TestStand 4.0 to 4.1.1 ....
I tried the patch suggested and it refuses to load since it cannot find TS version 4.1.0, which I have not yet found a source for.
Message 11 of 13
(1,466 Views)
Jim,
What is the expression you are evaluating and the data type of the parameter in question? How have you defined it within the Columns/Parameters tab of the Database Options dialog box?
Message 12 of 13
(1,464 Views)
Accepted by Rafi2003
My Access database version was 2000.... which is evidently too outdated for TestStand 4.1.1.
Our IT folks upgraded me to Access 2003, which seems to have cured all the errors I was getting trying to log data from TestStand.  I still have to rebuild several entries in my schema but it runs and logs without errors now.
Thanks for the multiple help attempts.
Message 13 of 13
(1,443 Views)
