NI TestStand
Db logging passed/failed as a 1/0
Hello!
I am currently working with TestStand 4.1 and I am trying to get my database logging to run.
I am using the Chema templates provided by TS. I have modified them for my use but one thing is making my life hard - UUT_STATUS (Exp : Logging.UUTResult.Status)
TS gives it "Passed" or "Failed" string but I need it to be "1" for Passed and "0" for Failed or atleast TS has to write 1/0 to my database, not Passed/Failed.
How would be the easiest way to accomplish this?
PS. I am very new to NI Teststand!
Sorry for my bad english, its not my native language.
(3,322 Views)
the easiest way (from my point of view) would be to duplicate the schema you are using, then modify this new schema by changing the UUT_STATUS column Type to numeric then modify the expression field to convert the True/False string to 1 or 0.
Rodéric L
Certified LabVIEW Architect
(3,314 Views)
@Rodéric wrote:
...then modify the expression field to convert the True/False string to 1 or 0.
I would be great if You could give me an example! I am a n00b!
(3,310 Views)
Accepted by topic author zero2rule
Got it working!
StrComp
( Logging.UUTResult.Status,"Failed",1,4)
(3,291 Views)
