NI TestStand
how integrate a CVI code in Test Stand
I'm learning my self to use both Labwindows and Test Stand and i have some problems.
I want to generate 5V from my NI PCI 6509 in order to drive relays so i think to use the C code from Finder Examples in Labwindows(WriteDigChan.prj).
I tried to call this CVI code from Test Stand but I couldn't.I need to insert the WriteDigChan.dll in "Module".I don't find the .dll so i tried to create it but it dosen't work at all.
Is that .dll necessary?
Any suggestion please!
Best Regards,
Message 1 of 10
(4,327 Views)
Yes, that dll is necessary. I don't have CVI on my machine but if I recall correctly there should be full working examples, including dlls, in the Example folder for CVI.
CTA, CLA, MTFBWY
Message 2 of 10
(4,301 Views)
Ok that's understood....but "if i call correctly" that is what i need would tell me please how i CORRECTLY call a cvi from Test Stand.
Message 3 of 10
(4,291 Views)
checkout the example "computer.seq" in <teststand>\Examples\Demo\C\
Regards
Ray Farmer
Message 4 of 10
(4,289 Views)
It always shows me this error 😞
Message 5 of 10
(4,285 Views)
is function a defined as a DLLEXPORT?
Regards
Ray Farmer
Message 6 of 10
(4,281 Views)
No..should i declare my function with DLLSTDCALL!
Message 7 of 10
(4,278 Views)
i mean DLLExport sorry
Message 8 of 10
(4,277 Views)
You need to export the functions that you want visible for other external applications, such as teststand, to use.
Checkout the computer.prj associated with computer.seq example.
Regards
Ray Farmer
Message 9 of 10
(4,269 Views)
OK i'll try,thanks.
Message 10 of 10
(4,267 Views)
