Deactivate UUT Result Popup after UUT finished
I want to test a sequence automatically x times. I have a labview.vi that count the uut serial number up so I don't need to set every time the number by myself. But after every sequence/uut I have to check the UUT Result popup to run the next sequence/uut.
Is it possible to deactivate this popup that the next uut can run automatically if the last finished?
I use Teststand 2010.
(3,524 Views)
Accepted by Rokot
You can use the PostUUT/PreUUT Callbacks.
(3,518 Views)
It works, thanks.
(3,502 Views)
