NI TestStand
Default parameters in step types
Hi
I got a type definition for a cluster that contain some path types.
In these path types I have set a default value
The I have a VI that I load into a LV pass/fail step. This VI has a input like Cluster step type.
How do I get the default values fro the Type def. to show in the step parameters?
Thanks in advance
Bjarne
(637 Views)
Have you configured the Cluster Passing in your TestStand TypeDef?
(635 Views)
Like this?
No difference
(630 Views)
Guess you set this for all cluster members, right?
This is the "Synchronization" between the LabVIEW and the TestStand TypeDef
If that doesn't do the job... I am out of idea for the moment.
Though you could try to cresate a new step of this type and assign the VI again. Just in case we are seeing some kind of refresh issues here
(626 Views)
Yes I did, but thanks anyway 😉
(622 Views)
