NI TestStand
Lock Synchronization
I have a sequence that works in parallel mode with test sockets. All are using a DAQ, whose subvi are with "Clone execution" (VI Properties/Execution/Reentrancy), despite this I have errors that the source is reserved.
In the Steps that use this DAQ subvis in "properties"/"Synchronization" I have selected the "Use Lock to allow Only Thread at a Time to Execute the Step" with the same Lock Name for all and in Batch Synchronization: "Serial(one thread at a time)", but I'm not sure if this is the right option or "Use sequence file at a time".
I have searched in the manual but I cannot find the different options in this case explained.
Can you please help me with this?
Thanks so much in advance!!
(993 Views)
I don't understand your case completely, but maybe the folloing might help:
- changing reentrancy settings on driver VIs will enable the VIs to be called in parallel, yet I doesn't make the hardware ressource available for all parallel threads at the same time). Reserved Resource error message indicates, that one thread/ execution has reserved the ressource while the others are denied access.
- The Synchronization Steps/ Options you are referring to are only functional with the Batch Model not with the Parallel .  In the Parallel Model, you have to use lock steps.
(958 Views)
Hello Oli,
thank you very much for your response. So it's just doing the Lock for me? It doesn't matter what I am selecting in "Batch Synchronization",right?
Is this Lock in synchronization/Properties the same as the one used in "Insert Step"/"Synchronization/Lock?
thanks so much for your time!!
(955 Views)
Accepted by topic author Elfernro
@Elfernro wrote:
Hello Oli,
Exactly. Will be used only by the Batch Model
Same but different 😉
The Lock Property you can configure in the step settings only refers to this very step. If you need to include more than one step in a locked section, you better off defining a section by using dedicated Lock Steps.
Though I have to admit, I do prefer using explicit lock steps also for just a single one, since it doesn't hide the property somewhere in the step.
(948 Views)
Now everything is clear. Thank you very much!!
(943 Views)
