NI TestStand
Definition of Module Pathnames for substeps of new Step Types
Good morning,
I developed a DLL in CVI containing the functions called for Edit and Post substeps of new step types which work fine executing them from a sequence file but i have the following problem:
I created a new type palette file (*.ini) containing those step types and i harcoded the "Module Pathname" when specifying modules of those substeps in TestStand for my PC but i need the final user can define where the DLL is stored in other computer so that this DLL can be found by the type palette file and then, the sequence file can be run without any problem.
Alejandro
(2,666 Views)
Write the name of the DLL without the path in your substeps, and use the search directories to tell to TestStand where the DLL is. Each computer can have different search directories depending where the dll is
Regards
(2,655 Views)
