NI TestStand
TestStand loading Vi's incorrectly, squashing controls
Hi All,
I'm new to TestStand (and LabView!) and am trying to create a Pre-Check Vi for the sequence I want to run. Here's what the Vi looks like when run in LabView:
It looks OK, and I'm happy with it.
Here's what it looks like when called from TestStand:
Can anyone explain to me why this is happening and how I can fix it without a lot of trial and error moving things around?
(3,475 Views)
Are you running the VIs in the LV RTE or in DevEnv (LV adapter setting)?
Does this affect only this VI or others as well?
Is the panel itself of the same size? If not, do you have "scale objects with pane" selected?
Norbert
Expert: Geometry
(3,463 Views)
Accepted by topic author Lbee11
If you run this VI from TestStand using LabVIEW Run-Time Engine, as
Sincerely, kosist90
JKI VI Tester – useful tool for LabVIEW developer
(3,439 Views)
Thanks kosist,
Turns out there was a font issue, but it was also made worse by windows DPI settings, I've changed the behavior of windows and now its OK.
(3,396 Views)
