NI TestStand
Delay in running sequence file from user interface
I have a TestStand sequence file which calls more than 60 different LabVIEW modules from 2 LabVIEW project files(Relative path method has been used to call modules). If I run this sequence file from TestStand, TestSTand is taking lesser than 5 secs to load and start executing the steps, but if run the same seq file from LabVIEW user interface its taking more than 2 minutes.
What could be the reason?
More Info:
TS version : 4.5.0.310
LabVIEW: 2010
In UI Run button has been bound to 'CommandKind_ExecutionEntryPoints_Set' with set point 2(Run UUT)
Run Environment: Development
Thank you
AP
Adarsh
CLA - Certified LabVIEW
Architect
https://www.youracclaim.com/badges/4871da75-1b8b-422a-a881-9ab206d2d36d/public_url
(3,308 Views)
Are modules already preloaded in both cases (i.e. how long does it take the second time you run)? Is your LabVIEW UI also running in the development environment? Do you have multiple calls to the save VIs? What are your paths relative to? Do you have any custom search directories? Are these comparisons both on the same machine?
-Doug
(3,296 Views)
Thanks for the reply. Please find my answers in bold letters.
No, They are not preloaded, but I can’t manually load the files. It takes less time in sec run.
Yes.
Yes in some places
Sequence file
No.
Yes.
Adarsh
Adarsh
Architect
(3,281 Views)
Accepted by topic author Adarsh
This is a known issue that occurs when both the UI and the code modules are running in with the same LabVIEW runtime engine, or both are running in the LabVIEW development environment, or the UI is running in the development environment and the VIs are running in the same version of LabVIEW's runtime engine as the development environment being used. There are a couple of things you can do that should help.
1) If you build your UI into an exe so that it is using the LabVIEW runtime engine and your code modules are using the LabVIEW development environment then this problem should go away and you should see speeds similar to the TestStand sequence editor. In this case the UI and the code module VIs are running in separate processes.
2) TestStand 2010 sp1 mitigates this issue somewhat for the case in which you load the same VIs mutiple times by caching the information it needs from labview rather than getting it again for each step which uses the VI. This will only make a significant difference if you have a signficant number of steps calling the same VIs.
Hope this helps,
-Doug
(3,260 Views)
Hi.
Its working !!!!!
Thank you
AP
Adarsh
Architect
(3,245 Views)
