NI TestStand
Deploy sequence
i have created a sequence in TestStand 2022Q4 with .NET and LabVIEW Steps (vi in , .vlib libraries). I have deployed the sequence with all the dependences but, even if the target PC has TestStand installe
i have created a sequence in TestStand 2022Q4 with .NET and LabVIEW Steps (vi in , .vlib libraries). I have deployed the sequence with all the dependences but, even if the target PC has TestStand installed, it doesn’t recognize the sequence as .seq. it seems like no TestStand exe are installed for running the sequence. On NI license manager everything is activated. I don’t understand what happened and where to find a simple interface for TestStand just to run the sequence. Where I go wrong? Here my configuar file.
Thank you for the help!
Zuc
Also because only the full build is generated without error...
Zuc
(357 Views)
Moreover when i open the sequence with a Simple UI (the once alredy presente in <TestStand\UserInterfaces>) i receive the error:
 But i developed the library in LV2019 and they are in the correct path. I can't understand what happenening. I have sopposed that Teststand was easy to deploy as Labview.
Best Regards,
Zuc
(344 Views)
i found my problem. The RunTime Engine wasn't installed with all the other application. I don't get why since in the deploy everything seems fine and the Labview adapter correctly detected the right version of the active Labview. So i don't get where to check if there is any problem in the deploy package.
Moreover is there anyone who know how to set the Maintainer field visible by NI package Manager so that insted of NI the Company name will be visible?
Best Regards.
Zuc
(323 Views)
