NI TestStand
Deployed project will not run the delopyed sequences
I have been going back and forth with NI for months now with my project. I have built many projects and deployments over the years and this one is about to drive me nuts. I was having issues with the development package converting a seq from dev mode to runtime. I now have these issues fixed. I can run the system on the development machine with the seq in runtime mode no issues.
I created a deployment with a Teststand workspace, included all of the files and the User interface exe and it will build. When I install on the deployment machine and run the exe I get the error attached.
It seems to be that it all boils down to any VI that contains the Database toolkit vi's will not release in runtime. I have LV 2017 and the Database toolkit 2017 installed. I would think that if these are the issue it would not run on the dev machine.
All depends on my login since I have development license but when I run the system with the base deployment license it will not run on any machine.
Bill Lewis
(2,204 Views)
Have you recompiled your toolkit in LabVIEW 2017.
Regards
Ray Farmer
(2,181 Views)
yes it is recompiled
Bill Lewis
(2,164 Views)
