NI TestStand
<UUTStatus> possible Values
Hi all,
I'm developing my own model plugin and I  have to know if the test is OK or failed (failure or runtime error or terminated or arborted) in "UUT Done" callback
There is variable Parameters.UUTStatus string. Does it take predefined values? If yes, what are the possible values?
Thanks in advance for your help
(2,485 Views)
Accepted by topic author maxmont
Technically since it is a string then my guess is it could be anything, depending on how you wrote/modified the process model.
Natively I think the sequential model only returns 4 values.  The reason I think this is because if you look in DoPostUUT sequence in the process model it only handles the 4 scenarios.  I can't find documentation anywhere about all of the possibilities other than this.
They are:
Passed
Failed
Error
Terminated
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,450 Views)
OK, so If I understood, the 4 states are : "Passed", "Failed", "Error", "Terminated" ?
(2,438 Views)
Correct!
jigg
CTA, CLA
testeract.com
(2,420 Views)
