NI TestStand
Deploying Modified Front End Callback
Using the teststand deployment utility I need to installer with the MSI installer a modified front end call back. What is the correct method to do this?
I have the box checked
the build yields
Is there not a way to have the MSI installer automatically install this ?
Which directory does it need to go in for the runtime to use?
  • C:\Program Files (x86)\National Instruments\TestStand 2022\Components\Callbacks\FrontEnd
or
  • C:\Users\Public\Documents\National Instruments\TestStand 2022 (32-bit)\Components\Callbacks\FrontEnd
Whats the difference?
(484 Views)
Any user customization should go under <TestStand Public> directory. The <Program Files> directory is for any standard NI's customization.
Santhosh
Soliton Technologies
(474 Views)
