NI TestStand
vi broken when run in "no visible window applications" but does not have issue when run in sequence editor or TestStand example UI
Hi, I have a non-visible window application (contain ApplicationMgr, SequenceFileViewMgr, ExecutionViewMgr and SemiconductorModuleManagerFactory). There is no error when I run a test program sequence file in TestStand sequence editor, however I got a "vi broken" error when I run using my custom UI. This happen to when I configure the LabVIEW adapter to RTE or even Development System. I check the vi that causing the error, I do not see the "broken run arrow" in LabVIEW and I am able to run the vi. I am guessing that the issue happen when LabVIEW not able to find nidcpower.llb or nidcpower_64.dll when I run the sequence file using custom UI.
What is the possible root cause and what is the different when I run using custom UI compare to run in sequence editor?
Environment: LV 2020 64bit , TestStand 2021 64bit
Thanks in advance
(733 Views)
Try changing the version/bitness of the TestStand LabVIEW adapter.
I think I misread the question.  Not sure I understand it, sorry.
CLA
(687 Views)
Sounds tricky....is the NIDC Power related code the first LabVIEW Code which gets executed? If you comment out "Init DCStuff", will you see other broken VIs then?
(667 Views)
Update on my findings:
I realize that I need to configure the complete file path of the dll file for "Call Library Function Node". the default value was nidcpower_*.*
The vi file that use the dll is "niDCPower Initialize With Channels.vi"
Is there any configuration that can configure where the LabVIEW runtime will search for the dll so that I can remain the default value as nidcpower_*.*
But I am also curious that why this error does not appear when I run the sequence file using sequence editor (also using LabVIEW runtime)
(657 Views)
