NI TestStand
Detecting current parent (exe) application
Is there a way to detect which user interface is currently running ?
I want to detect, in the process model, if the user is currently running the 'standard' SeqEdit.exe or a custom user interface.
Maybe is it possible with the Engine.Caller but I have at this moment no clue how to do this.
TIA.
(3,259 Views)
You can try to guess the name by using this solution:
I'm using a tool from the Sysinternals suite: PsTools -> PsList
Batchfile:
echo off
PsList SeqEdit
if errorlevel 1 goto error
echo ---------- SeqEdit found -----------
goto end
:error
echo ----------- not found --------------
:end
pause
Or the "PsList" can also be used as a "Call Executable" step.
Message Edited by Martin Greil on 04-05-2010 04:04 AM
(3,247 Views)
Accepted by FOstyn
Thanks Martin for your suggestion.
It's not exactly what I was looking for, because I didn't want to create a new (extra) file (batch or dll,..) .
But it helped me to re-think my problem and of course...
In our process model, we create an instance of a (.NET) custom dll, so, .NET has a Process class and the GetCurrentProcess() method returns the name of the current (exe) application...
Thanks.
(3,233 Views)
