NI TestStand
Determine the Size of Each Dimension of a 2D Array in TestStand
How do I determine the size of each dimension of a 2D array in TestStand?  myArray.GetNumElements() returns to TOTAL number of elements in the (2D) array and doesn't help me.  I need to iterate over only one dimension.
Thank you,
Andrew
(8,273 Views)
Look at GetDimensions, GetDimensionsSizes, GetUpperBounds, and GetLowerBounds and decide which suit your case best.
- James
(8,272 Views)
GetUpperBounds(int dimension) is exactly what I need.  Unfortunately, it doesn't seem to be present:
Error in call to TestStand API member 'PropertyObject.GetUpperBounds'.
Method 'GetUpperBounds' does not exist in interface 'PropertyObject'.
This is the result of code:  Locals.my2Darray.GetUpperBounds(0)
(8,268 Views)
P.S.  I am using TestStand 4.2
(8,266 Views)
Try Locals.My2dArray.Type.ArrayDimensions.GetUpperBounds()
(8,234 Views)
Accepted by topic author awdeorio
GetUpperBounds exists but just not in that context. Try something like the following...
Locals.MyDimensions = Locals.MyArray.Type.ArrayDimensions.GetUpperBounds ()
Where Locals.MyArray is your 2-d array that you want the dimensions of and Locals.MyDimensions is a 1-d array to store the dimensions. Something like...
Locals.MyArray.Type.ArrayDimensions.GetUpperBounds()[0]
... would work as well, this example would return the number of elements in the first dimension of Locals.MyArray.
Steven Zittrower
http://www.ni.com/support
(8,232 Views)
