NI TestStand
StepInto does not work in UI
When I attempt to step into a test module in vb.net using the Sequence Editor everything works fine. However, if I set a break point using the full featured UI provided with TestStand it breaks at the step but when I step into the step I get an error message.
Any ideas as to why? This would sure be a nice feature to work and in fact is one of the main reasons we selected TestStand.
Thanks.
(3,420 Views)
Accepted by topic author Skeptical
I figured out that I only have a problem when I am running the UI program in debug mode. If I run from the exe, I have no problem.
(3,403 Views)
