NI TestStand
DetermineReportFilePathNameExprEx2
My system
  • Windows 7 32 bit
  • Testand 2014 SP1 (14.0.1.103) 32 bit
  • Sequence Editor Version 14.0.1.103
I use "DetermineReportFilePathNameExprEx2" contained in modelsupport2.dll (see the attached image). I pass an empty string to uutPartNum. But now the file name in "ClientFileName" in the "Report File Pathname Tab" is not present in the file name of the report in the file system. Instead it is replaced by some "UnsavedSequenceFile" part in the file name. But the affected sequence file of course is saved.
Curiously in the window for the "Report Options" -> "Report File Pathname Tab" the "ClientFileName" makro is evaliuated correctly as shown below ("testprüffall.seq" is its file name in this case). The various makros here are assembled correctly.
How can i take care that the file name is correct ?
(2,646 Views)
is your question still active?
What do you want to achieve?
If you attach a reduced sequence of what you are trying to do, I'll have a look 🙂
Greetings
(2,515 Views)
