NI TestStand
How to find Configuration file in teststand using FindFile() Function
I am trying to search configuration file from teststand. When I execute the sequence it is showing me error as shown below. How to resolve this error? Error in call to TestStand API member 'IEngine.FindFile'. Specified value does not have the expected type.[Error Code: -17308, Specified value does not have the expected type. ]
(3,660 Views)
Probably one of the parameters of the FindFile function is not correct, can you show us how you use the function?
(3,658 Views)
Thanks for reply..
I used function as below:
Locals.FileFound =RunState.Engine.FindFile ( "154M2-105-0_02.csv", Locals.absolutePath, Locals.userCancelled, FindFile_PromptHonorUserPreference,  FindFile_AddDirToSrchList_Ask, False, "154M2-105-0.seq")
(3,651 Views)
The last parameter is wrong it must be a Sequence File object, try RunState.SequenceFile instead of "154M2-105-0.seq".
(3,637 Views)
I used below syntax for FindFile() function and it worked fine
Syntax:
Boolean FindFile(String fileToFind, Boolean useCurSeqFileDir = True, [String PathToFile], Number promptFlag = 1, Number searchFlag = 1, [Out] [Boolean canceled], Boolean isCommand = False)
Expression used :
FindFile ("154M2-108-0_02.csv",True, FileGlobals.absolutePath,1, 1, FileGlobals.userCancelled,    False )
Thanks for the help....
Sanket
(3,630 Views)
Yes that will work as well because the parameter is optional. See http://zone.ni.com/reference/en-XX/help/370052M-01/tsapiref/reftopics/engine_findfile_m/ for details about FindFile
(3,602 Views)
