NI TestStand
The Same Code Work Normal On TS2016 But Doesn't Word On TS2017
Hi Sir
As the title, the code below is normal on TS2016but does not work on TS2017, compile pass, but I was reported "index error", how to fixed it, thanks!
axSequenceFileViewMgrA.GetCommand(CommandKinds.CommandKind_ExecutionEntryPoints_Set,1).Execute(false);
Thanks!
(2,971 Views)
Accepted by topic author TabZhang
That code is indexing the set of execution entry points. I bet in your 2017 setup, you either don't have a process model selected, or your process model has less than two Execution Entry Point sequences.
The NI models all have two Execution Entry Points: Test UUTs and Single Pass.
(2,935 Views)
Hi James
Thanks for your suggestion.
I use SequentialModel.seq attached which only do a little modified base on the default models in TS2017.
That is to say, it has two Execution Entry Points: Test UUTs and Single Pass.
(2,904 Views)
After I copied  the whole "Components" folder to my Release folder, the problem was solved, thanks!
(2,900 Views)
