NI TestStand
Developing a method for repair actions for a sequence
I want to design a sequence in teststand that when each test fails, the sequence execution stops and indicates the repair action.  I do not see a repair action in any of the fields in the dialogs for each step to edit.  I just want to run a series of tests and when one fails, ahve a callout for repair.  How do you do this in teststand?
(3,651 Views)
Accepted by id
SequenceFilePostStepFailure callback.  It gets triggered whenever a step fails.
Here is an example on one way to use it: https://www.ni.com/docs/en-US/bundle/teststand/page/overriding-engine-callbacks-sequencefileposts.ht...
Instead of what they are doing in the example you can just have a popup instructing the tester to go run the repair.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,649 Views)
