NI TestStand
Development settings not transferring to deployment.
Hi all,
I am using TestStand with the parallel process model to test 16 UUTs. After much head banging I found out that I needed to include TestExec.ini to force the deployment to use the parallel model.  What other files to I need to include for settings to transfer to the deployment? These settings specifically being:
  • Disabled report generation
  • Number of Test Sockets
  • Other settings that I cant think of at the moment...
I should note that this is my first TestStand deployment.
Thanks!
(4,689 Views)
Hi ademedeiros,
You may also need to include TeststandModelReportOptions.ini and ResultsProcessing.cfg if you are having trouble with your deployment. Generally this should be taken care of and there shouldn't be much on your part to move manually, but if for some reason you do, try transferring these files. You can also read a little bit more about TestStand Deployments in this support article. I hope this helps.
http://digital.ni.com/public.nsf/allkb/EE3382373D209449862570A5006572F0
Paul C
Paul C
(4,558 Views)
Paul,
Thank you for the helpful reply. I have actually ran into other forum posts regarding those two files you mention, but I cannot locateTestStandModelReportOptions.ini in my system.I asume it would be located here: C:\ProgramData\National Instruments\TestStand 2014 (64-bit)\Cfg?
Thanks!
(4,545 Views)
Accepted by topic author ademedeiros
After looking into it a little more, it appears that TestStandModelReportIOptions.ini and TestStandModelDatabaseOptions.ini have both been replaced by ResultProcessing.cfg, so that should be the only file you need!
Paul C
(4,528 Views)
