‎03-02-2010 12:41 AM
Hi Ppl,
Are the API's for using the "Diff Sequence File With" tool exposed ? I mean the tool thats available in the Sequence Editor ->Edit->Diff Sequence File With
I want to use this tool programmatically. I searched the TestStandAPIReferencePoster. I couldn't locate any such method.
This tool is not available with the custom sequence editor license. So If I want to have this functionality in a custom sequence editor is there any work around ?
‎03-02-2010 05:16 PM
The diff APIs are exposed, but not documented or supported. They are also subject to change.
However, you should be able to redistribute C:\Program Files\National Instruments\<TestStand>\Bin\SequenceFileDiffer.exe
I believe it works with a custom editor license.
‎03-05-2010 05:59 AM
Hi James,
If I want to embed this sequence file difference tool as a part of my custom sequence editor, how can i do it ? Are there any Activex controls for this ? Or should I launch it only through the exe that you have pointed out.
‎03-05-2010 10:29 AM
‎11-12-2018 02:03 AM
Hi All,
I have a requirement to compare two sequence files programmatically and find what are the steps that have been changed. Please let me know if the Diff Sequence File utility APIs are exposed by NI in the recent versions of TestStand.
Sree
