NI TestStand
Directly write data into TDMS file in TestStand without any other adapter
I am using TestStand 2023 Q4 and the test sequence call python modules in each of the test steps. So I will have some large tables/arrays of test data in TestStand variables, and I want to save the data into TDMS files directly without calling LabVIEW or other modules. I found following link and example but they are not the right answer I am looking for. Is there an example/adapter that I can save TestStand variable values (data) into TDMS format files directly? Thank you so much!
write TDMS file in TestStand using dotNET adapter - NI Community
Message 1 of 1
(485 Views)
