NI TestStand
programmatically create sequenceCall in testStand
hellon
how can i create a sequence call programmatically in new Step using TestStand API?
(2,919 Views)
Accepted by topic author hakimS
See Solved: TestStand API - Sequence Call
Basically, it is a Engine.NewStep method with StepTypes set to "SequenceCall".
(2,896 Views)
thanks ,
it is helpful
please how can i make it in statement step in testStand?
(2,877 Views)
@hakimS wrote:
thanks ,
it is helpful
See Building a Sequence Using API - TestStand Expressions (XML)
(2,852 Views)
I am using Python to translate code to a teststand 2017 sequence. I need to set  function parameters and don't know how.
This is what I do to create the step and set name and use current file property. It works so far, but when I open the generated sequence file there is a red exclamation mark stating that the arguments do not match the parameters of the sequence to be called.
If i use step.Module.UsePrototype = True then the exclamation mark is gone, but the Use prototype checkbox in the generated step is UNchecked.
This is an extract from my code.
step = engine.NewStep("Sequence Adapter","SequenceCall")
step.Name = (step.StepType.Name) +" "+ str(index)
step.Module.UseCurFile = True
step.Module.SeqName = sub_seq.name
#ToDo: Set Parameters "Var1" to 10
MainSEQref.InsertStep(step,index, stepGroup["StepGroup_Main"])
Can anyone help please? I assume I have to do something with the step.Module.ActualArgs Property but I am stuck for two weeks at this problem now and I have tried almost everything.
(1,839 Views)
