NI TestStand
Multiple Pass Binning
Hi, I am new to teststand. I am trying to get 3 pass bins which are 1,2,3 respectively. There is a test that has the same test name but different test limits. Each of them should have a different pass bin but will continue on fail for 1 and 2 only.
Example Error Value = 13
(1) Error 0Llim 5 Hlim = Bin 1 "Fail"
(2) Error 0Llim 10 Hlim = Bin 2 "Fail"
(3) Error 0Llim 15 Hlim = Bin 3 "Pass"
Basically, the test will continue on fail but the final pass bin result should be bin 3. I want to know how is this possible with NI Teststand.
Thank you in advance.
(766 Views)
Are you using TestStand Semiconductor Module or just TestStand?
Santhosh
Soliton Technologies
(752 Views)
Hi Santhosh,
Yes, I am using the TestStand Semiconductor Module. This is for my ATE Solution.
Regards.
(743 Views)
Accepted by topic author ArenSia
This concept is close to grading; there will be an example of how to do this. I don't have TSM installed to point exactly where it is but if you explore the TestStand examples, you will find it.
https://www.ni.com/docs/en-US/bundle/teststand-semiconductor-module/page/grading-passed-duts.html
Santhosh
(738 Views)
Yes, grading is exactly what I was looking for I didn't know what it was called at first thank you so much. I will look into the link.
(729 Views)
