Display user groups and privileges
Hello world!
I'm trying to build with LabView a custom operator interface for TestStand. I've already realized a VI whose front panel contain a listbox where are displayed all available TestStand users (see attached file). Once selected a user by clicking on its name, it is displayed in the string control.
Now, besides displaying selected user name, I would like to display: in a listbox, the list of groups (Administrator, Operator, ...) to which selected user belongs; in another listbox, the list of privileges owned by selected user.
How can i do this?
(5,171 Views)
try to consider this KB, this forum post and this one for some examples.
I hope this will help!
Bye!
Licia
(5,141 Views)
Accepted by aRCo
Thanks LiciaP!
Following your suggestions too, i succeeded doing what i wanted.
See attached VI for the solution. Considering that i'm a novice, i ask if someone can check the block diagram in order to suggest code organization improvements.
Ciao
(5,103 Views)
You need to ask in the LabVIEW forum. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
(4,990 Views)
Just a few points.
When I run your VI and pressed the Exit button I received a number of not released objects message:-
References to PropertyObjects were not released properly.
    Total number of objects: 3
    Number of top-level objects: 3
    Note: Some top-level objects may be included if they are referenced by
    an incorrectly released top-level object. For example, an unreleased
    SequenceContext object references a SequenceFile object.
    The following top-level objects were not released:
        PropertyObjects [3 object(s) not released]
            PropertyObject #1:
                Type: Array of Strings
            PropertyObject #2:
            PropertyObject #3:
Basically your while loop was iterating for 4 but I only had 2 users setup, therefore the GetNumElements was 0 for 3 of the groups which generated 3 PropertyObjects which were not released because the for loop wasn't being performed.
So I have put the for loop in a case statement (see attached)
You have a number of GetEngine calls which you could aviod using by just passing the Engine reference in from the Initial GetEngine.
You have a string array in a for loop and a const controlling the number of iteration, use the size of the string array to do that job
Not sure why you have 2 Operator entries in the Groups array as you stop the loop at the first one.
Regards
Ray Farmer
Message Edited by Ray Farmer on 09-11-2009 09:52 PM
Regards
Ray Farmer
(4,975 Views)
I had a little play with your example (this was using LabVIEW 8.6)
Regards
Ray Farmer
Message Edited by Ray Farmer on 09-15-2009 09:59 PM
Message Edited by Ray Farmer on 09-15-2009 10:02 PM
Message Edited by Ray Farmer on 09-15-2009 10:03 PM
Message Edited by Ray Farmer on 09-15-2009 10:04 PM
Regards
Ray Farmer
(4,942 Views)
