NI TestStand
DisplayExecution event not triggered after sequencefile execution
I have a problem now with my customized Test UI developed in C#.
In my own PC, my codes works well:
this.axSequenceFileViewMgr1.GetCommand(CommandKinds.CommandKind_ExecutionEntryPoints_Set, 0).Execute(true);
// Run sequence---> This goes to DisplayExecution event
private void axApplicationMgr1_DisplayExecution(object sender, NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_DisplayExecutionEvent e)
            this.axExecutionViewMgr1.Execution = e.exec;
However, when I run this UI in another PC, which installed same softwares as mine, the DisplayExecution can not be triggered.
And I found that the count of Executions in axApplicationMgr1 is always 0 after the command execute.
I'm using TestStand 2014, 64bits version.
C# in Visual studio 2010.
Please advise where may go wrong in my code or the PC environment for my problem.
Thanks alot!
(4,682 Views)
I figured out the reason of this issue by myself.
The failure of not doing the GetCommand.Execute() is due to the user login issue.
During my development I feel the login window is annoying so I disabled it by setting axApplicationMgr1.LoginOnStart to false.
I'm not sure why it works in my PC but not in others. -> Maybe someone can advise on this point?
So my current solution is to catch the UserChanged event after the login then to open the sequence file and execute it.
Hope this is helpful to those meet similar issues.
(4,578 Views)
The first thing I would check is to open the Station Options dialog box on both machines and verify that the settings on the User Manager tab are the same.
(4,563 Views)
oh yes.. I double checked the User Manager settings, to find that my own PC the "Check User Privileges" was unchecked but it was checked at the "Not OK" PC .
Now both PCs  are aligned and my original program works too!
Thanks James for your suggestions!!
(4,554 Views)
