NI TestStand
character comparison
I have a string in TestStand that contains letters and numbers; is there a way of comparing each character within the string to see whether it is either a [A..Z] or a [0..9]?
(5,029 Views)
Here is a hacky solution.  You might be better going to a code module or creating your own step type.
Just a thought.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,944 Views)
Thanks for that, it works well.
I dont understand the 65//A & 90//Z though; "//" is normally a comment; what is this function, it does not appear to be listed in my version of TestStand but works anyway?
(4,919 Views)
You can put just 65.  // is a comment.  I put it so that you knew 65 was A.  I'm just used to commenting code so if I ever come back I will know what it means.
Glad it worked.
jigg
CTA, CLA
testeract.com
(4,913 Views)
