NI TestStand
Distribution contains invalid dependencies...
When I do a build (using the same tsd file) on differing machines I get different results.  Some machines work just fine & the installer works and the seq files will run.
One other machine can build the tsd file once just fine.  I can also just create a new tsd file with the same configurations just fine too.  But if I build it again...or build another's tsd file, I get this when installingScreenHunter_03 May. 31 11.02.jpg
Anyone got any ideas out there?
This does use adapters [LabView 2011, LabWindowsCVI 2011, .NET DLL] and runs under TestStand 2011 SP1.  Those are selected on tab page Installer Options  [Drivers & Components] and the CVI adapter dlls/objs/libs are included in the list of distrubuted files on the left.
I have noticed on this machine that the auto-loading of the labwindows cvi dlls/objs/libs doesn't like to stay set in TestStand itself.
www.certtech.com
(3,198 Views)
The development software on each of the benches is probably different which is why you're seeing the error. Make the dev software the same on both and I guarantee this goes away (i.e. install the EXACT same drivers from the EXACT same DVDs or network location)
CTA, CLA, MTFBWY
(3,194 Views)
