NI TestStand
Does TestStand understand NaN?
I am using the latest LabVIEW VIs for the HP34401A DMM.
When measuring an open circuit, these VIs return a NaN (Not a Number).
When TestStand receives this value, it displays it as "-1.#IND" in the
report.
Curiously, I can make a numeric test pass when passed a NaN by setting
the comparison type to "EQ" and putting ANY number in the numeric text
box. (=1, =-1, =2313, etc.) I believe this holds true for other NaNs
like positive infinity and negative infinity ("1.#INF" and "-1.#INF").
Is there a better way to handle a NaN other than intercepting it within
LabVIEW, testing for NaN, and changing the value to a very large
positive or negative number before passing it on to TestStand?
Howard
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(7,201 Views)
In article <7m0kjb$qpc$1@nnrp1.deja.com>,
I meant to write: When measuring the resistance of an open circuit...
Howard
(7,201 Views)
Howard,
You are correct, TestStand does not explicitly recognize "non-number"
numbers.
I will put this in as a candidate feature for a future release,
possible 2.0.
- James
In article <7m0l2k$qvo$1@nnrp1.deja.com>,
Number).
> Howard
(7,201 Views)
