NI TestStand
run time interface
Is anyone using any of the run-time interfaces?
It seems to be a mess. Nothing is in any of the directories stated in
the manuals. The LabView VI for creating one won't load as the TestStand
release disk doesn't seem to copy all the SubVi's or the SubVi's are
missing or something.
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(6,333 Views)
Can you give me some examples where the directories are incorrectly
stated in the manuals?
Are you making a LV Runtime Server? If so, we've improved the process
in TestStand 1.0.1 by using a build script. If interested in beta
testing TS 1.0.1, send an email to paul.mueller@natinst.com with your
name, company, address, phone num.
You will need to use Assemble Test VIs to assemble your test code. Did
you do this?
There is a drawback with the current Assemble Test VIs. Currently,
this only works on 1 seq file. When TS 1.0.1 releases, there will be
an implementation which works on multiple seq files.
Hope this helps. If you respond with specific information about what
you are doing, we can better help.
Paul
In article <7mvb88$svg$1@nnrp1.deja.com>,
emv
TestStand
(6,333 Views)
