NI TestStand
Does Teststand require NISE to see switching routes?
After I have used NI Switch Executive to create routes and virtual devices, I can use these for switching under the switching tab in Teststand but, I was wondering if there is a way or if I would need NISE for application developers who will be writing code in Testand.  Does the application engineer need NISE in order to use the routes as well or is there a way in which Teststand can parse or read the routes already created by NISE?
(2,892 Views)
I believe the answer is that you must must NISE installed otherwise the Switching is not enable in the step properties.
Regards
Ray Farmer
Regards
Ray Farmer
(2,885 Views)
