After I have used NI Switch Executive to create routes and virtual devices, I can use these for switching under the switching tab in Teststand but, I was wondering if there is a way or if I would need NISE for application developers who will be writing code in Testand. Does the application engineer need NISE in order to use the routes as well or is there a way in which Teststand can parse or read the routes already created by NISE?
