NI TestStand
Don't prompt to save file when try to close a modified sequence file
  I built a custom step type in Teststand. It contains two parts: post substep is used to execute and edit substep with a UIR is used to configure setting. I hope after I change settings in edit substep UIR and try to close that seq file, Teststand could give me a warning which tells me to save sequence file because I have changed the file. Unfortunately, Teststand don't do that for me.  I think Teststand should have that function
 So my question is: What can I do if I hope that kind of function works? Is there anything that I missed when building a custom step type?
Regards!
Jacky
(3,406 Views)
You need to update the numeric value: RunState.InitialSelection.SelectedFile.ChangeCount. Add 1 if a change in your edit has occured.
Regards
Tom Andres Lomsdalen, CTD
(3,402 Views)
