NI TestStand
How to edit group of steps
I have a situation where I use an existing project as a starting point to new project.  So, I copied all CVI steps and sequences to the new directory.  I recompiled the dlls for the new directory.  Now, in TestStand I need to modify all the CVI steps so that the project the 'c' fiel and the dll are in the new directory.
I was just wondering I there is a better way to do it rather than go one by one.
Rafi
(2,934 Views)
Load all your files. In the Sequence Editor, select View>>Paths.
You can now change all occurrences of a path with one edit.
(2,929 Views)
