NI TestStand
Double \\ passing Path to LV
Hi, I have to pass some path from TS to LV. I have always used the double slash \\. Is possible to use only one "\"? If I do it the string that LV gets is different from the original. I know that the "\" is a special character and the behavior depends of the following character.
Thanks all
(4,173 Views)
Accepted by logatto
Not sure why you are asking this as you already know the answer.
I surpose you could send an array of U8's rather than a string then in LabVIEW convert your array back to a string.
Regards
Ray Farmer
(4,160 Views)
I agree with Ray. You should send a code and then convert it to a charachter in LabVIEW.
Bye!
MarcoMar
National Instruments Italy
(4,155 Views)
Thanks guys.
(4,147 Views)
If your path is stored in a string variable you don't need double backslashes, you only need double backslashes if you have a string literal in an expression.
-Doug
(4,131 Views)
