ERROR: Object Reference not set to an instance of an object
TestStand 4.2.1 issue whenever I chose to execute Selected Steps I receive this error.  After receiving this error once, every action in TestStand generates this error popup.  Sequences still appear to run but this is very frustrating.
I there some setting missing that is causing this error to appear.  These sequences ran just fine in TestStand 3.5.
Message 1 of 9
(10,921 Views)
Is this using the SeqEditor?
regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 9
(10,918 Views)
Yes I am using the sequence editor.
Message 3 of 9
(10,914 Views)
Hi mvterry,
I have a few clarification questions for you:
  1. Is the same behavior exhibited in one of our shipping UIs found under Start>>Programs>>National Instruments>>TestStan>>User Interfaces?
  2. Is it always the same sequence/steps in that sequence that first causesthe problem?
  3. Once the problem occurs, is the only way of fixing it closing TestStand and reopening it?
Cheers,
Michael W
Message Edited by Online Courses on 06-04-2010 04:39 PM
Message 4 of 9
(10,876 Views)
Can you post a screen shot of the error you are receiving regards Ray Farmer
Regards
Ray Farmer
Message 5 of 9
(10,853 Views)
 1,  I am strictly using the developer interface in the seq editor.  We have no use for the Operator Interface as the test engineers who write the sequences are the only ones who execute them.
2. We utilize the Report Generator Toolkit from LabView.  It seems as though using the interfaces we designed with this interface causes the issue.  When we upgraded to 4.2.1 from 3.5, I think the IT group forgot to re-register the .dlls we were using with the toolkit.  I have went ahead and did that and have not experienced the problem again...yet.  I haven't executed any sequences with the report generator toolkit either so I am not ready to call it a solution.  Will attempt to execute one again today.
 3.  Once the issue occurs, the error returns for every mouse click, tab, or keystroke performed within TestStand.  It is necessary to close and restart TestStand to get rid of the error once it appears.
 Thanks for your response and I hope that I have fixed my own problem.  Will repost if this is not the case.
Message 6 of 9
(10,840 Views)
Once I experience the problem again, I will repost the screen shot.  My apologies for not doing this in my original post.
Thanks for your help.
Message 7 of 9
(10,838 Views)
error I am having a similar problem. When I try and launch test stand I get this error.
Message 8 of 9
(10,378 Views)
Go to the directory:
<User Directory>\Local Settings\Application Data\National Instruments\TestStand <version\
And delete the file layout_current.bin.
Then try starting the sequence editor.
Hope this helps,
-Doug
Message 9 of 9
(10,368 Views)
