NI TestStand
Edit step list configurations
In teststand 3 and earlier, when executing a sequence it was shown in a column the result of the step and the high limit and low limit
Now in TS 4 it is possible to edit the step list but i did not manage to show the step result . For example if i create a new column (type expression) and just put Step.Result.numeric, xhen executing the sequence I have a popup because for some steps there is no step.result.numeric available.
My question is how to have the same as TS 3 and earlier ( Result + limits in a column when executing a sequence)
(3,232 Views)
Try the following expression:
PropertyExists("Step.Result.Numeric")?Step.Result.Numeric:""
This will check if the property exists.  If it does, it will put the numeric value in.  If not, it will put a blank string in.
Allen P.
NI
(3,219 Views)
Note that the numeric measurement appears as part of the description for the numeric limit test. The default TestStand 4.0 step list configuration has a description column, just like previous versions.
I guessing that you probably know this and are purely interested in creating a custom step list configuration, but I wanted to be clear that this functionality has not been removed.
(3,211 Views)
